Hello everyone.
There is 6m boat that has to satisfy ISO requirements, but its deck is below waterline in maximum load condition (pic1)
There are several options in ISO standarts for non qiuck draining cockpit.
6.5.4 ISO 12217-1 says Recesses fitted to design category C boats using option 6 (pic2)
having a volume to retention level larger than (LHBHFM)/40, entirely contained within LH/2 of the bow shall either be quick-draining (overboard) or drain to the bilge in the same time or less.
The cockpit is lager then (LHBHFM)/40. Then I briefly calculated the time needed for draining and it was clear that bildge pump cannot provide such draining speed. As I understood #6 is not an option for this boat.
Choosing option 4 (pic2) means passing flotation test with flotation materials according Annex G.
Maybe someone knows if there are any other options to avoid flotation materials? Because it would be qiute difficult to organize a foam inside the boat.
Thanx
Thanx
