Markmysite
Junior Member
- Joined
- Jun 12, 2015
- Messages
- 10
- Reaction score
- Location
- Stuart, FL
Hi all. Just joined the forum and have been reading up on center of gravity and buoyancy. I purchased a custom tiki tritoon and wanted to have some opinions from those that understand engineering better than I do.
Here is the background... The boat was originally a 1989 24' JC Pontoon. The previous owner stripped it down and added hardwood floors over the decking, rails, a bar, and a center pontoon that goes back 18'. The toons are U shaped, non foam, and they are all 23" tall X 21" wide. He also added a top deck made out of 2x4's and metal roofing panels. The top deck is 8' wide X 9'6" long. There is also a front window that is held up that is 8' wide X 3' long The previous owner built it 3 years ago and used it as a charter boat part of the time. He would take 10-12 people out and it never tipped over for him so at first I wasn't worried about it. I never let people go up top while underway of course.
The top deck is my concern obviously. I calculated the weight (using 16lbs per 8' 2x4). The wood and metal roof weighs about 500lbs. I'm thinking the CoG changed a lot with that addition. The hardwood floors also weigh 500lbs so maybe it counter balances the roof structure. I always try to keep the people load distributed evenly and it's been fine. The logs submerge to a little over the middle with full gear and 6-8 people.
I put a lightweight motor on it recently (2003 Yamaha 2 stroke... Only 262lbs). It has a 50 gallon fresh water tank that weighs about 400 lbs when full. I use it to counter balance the batteries and anchors on the SB side only filling it part way usually. Otherwise the boat does go down about 2 " more on the SB side when at stable float. I had some ventilation issues in turns and waves so I lowered the motor all the way down (20" shaft) and now it's much better.
My concern is will this thing tip over? I had it out for Memorial Day weekend with 6 people on it and the channels got pretty choppy as the drunk people on the bigger boats zipped by me. The 3rd toon helps keep it from submarining but water does come over the front sometimes even with everyone closer to the stern. When we're stuck in a side roll because of the width of the channel and boats passing us we can't cut into the wake at the right angle. She got rocking pretty good a couple times and it freaked me out and lifted my captains chair up on one side.
How can I calculate the CoG and max capacity on this boat? Is there anything I can do to keep it more stable (other than removing the roof top)?
