Custom gel coat matching
Discussion in 'Fiberglass and Composite Boat Building' started by John Sakovits, Mar 14, 2019.
  1. John Sakovits
    John Sakovits Junior Member
    Can someone recommend a facility that does good custom gel coat matching from a chip. Ideally a "AA" match in all three light sources.
    I had someone but they left the company.
    Thanks for your advice !
  2. ondarvr
    Likes: 623, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
  3. John Sakovits
    Thanks for the reply. The person at gel coat products who was outstanding at providing matches left and never had good luck with Spectrum.
    Appreciate the feedback
  4. ondarvr
    I supplied both of those companies with their gel coat bases for a couple decades.
    If you are trying to match old or faded gel coat the results can be disappointing, that’s common.
    I don’t know of any other companies that do this as their main source of revenue.
    Wendy retired from GCP, but they use a computer to do color matches now. When did you last use product from them.
  5. ondarvr
    I should have asked how much you need, the amount can change your options.
  6. John Sakovits
    So really need a few quarts but would take a gallon or five gallon if required. I know Wendy retired but regeatfully I think the replacement does not have the same experience or ability to meet AA in all three light sources like Wendy was able to.
    Thanks for your help.
    PS - also tried Polynt with no luck on matching
  7. ondarvr
    The big players won’t be interested in anything less than a pail, and they don’t like doing custom one-off pails, they want drum orders, they don’t even like color matching single drums.
  8. John Sakovits
    I did find that out. So regretfully still searching for someone to perform similar work to when Wendy was there
  1. s2dm
  2. nickireson
  3. youngfella87
  4. jbeboatman
  5. robwilk37
  6. mrdebian
  7. Tops
  8. Two beers
  9. Tim McCraney
  10. John Slattery
