Note: This feature may not be available in some browsers.
It is looking good. Still wondering if you need to pull vac from above.
A big job. Wishing you the best. Dan
I can't offer help; it would be unprofessional. Hope others can. The only place that makes my uneducated brain worry is the lower edges of the raised sections. For some reason, they make me nervous like a caveman and thunder.
Happy Easter !!!
I plan on pulling vacuum from the 'forward' edge of the platform (closest edge in the picture). I think that some peel ply and breather cloth above the flow media along with CSM below the flow media in the center of the forward edge should pull the resin toward a central location.
Here is a diagram of what I am thinking for the runner setup . . .
The resin will be fed into the mold from 4 input locations and along the perimeter of the rear half of the mold. Then, into the inner sections of the mold via the 8 secondary runners. Hopefully, having longer runners toward the outer edges of the mold and shorter runners towards the middle will bring resin from the rear and outsides of the mold towards the front and center where there will be a vacuum line.
Any comments on this setup are welcome (please).
