@fpjeepy05 thanks for the DM I will take a look
update...
I am pretty much done with the hull. I did the last layer of S-glass on Sunday. Monday morning did some weave fill while the epoxy was still green, then yesterday sanded this smooth and all it needs is a few a final layers of very thin epoxy, then it'll be ready for paint.
Here it is BEFORE the S-glass, having just been washed.
Looks pretty snazzy, huh? The intention was the finish the bottom clear up to a few inches above the chines, then paint everything else red.
Problem with CF is that it has poor abrasion resistance, especially for something intended to last decades, and especially compared to S-glass, so it isn't a good final layer on the boat bottom. I gave this a lot of thought--so far, the S-glass hasn't been excellent as far as ending up fully and perfectly transparent, but I really intend for this to function as a durable work boat within its application.
Decided to encapsulated it in one final layer of 6oz S-glass, which means the bottom is 4oz warp E, 6oz S-glass (these layers were messed up in the vacuum process so they were heavily sanded leaving about the equivalent of a 6oz layer of mixed glass), 6oz CF twill vacuum processed to a few inches above the waterline, 6oz S-glass vacuum processed over everything.
Spent so, so long perfecting the CF, carefully sanding and weave filling (see above!). Then when I did that last layer of S-glass, I was a little worried about the amount of epoxy I had and slower than I should have been to get the bag on it, so during the wet-out I some portions got slightly overworked and ended up a tiny bit cloudy (microbubbles). The S-glass also seems to be very touchy as far as getting it to go on clear in general. So, the bright portions were a little bit mottled--not screamingly so but on inspection it isn't uniform clear CF weave. I got three options--1) forget about the CF and just paint that portion black, 2) live with the mottled look--I mean it's mostly the bottom of the boat for chrissakes, 3) or tint the bottom layers of epoxy and even clear urethane with UV proof black pigment to mute the cloudier CF portions so that it is semi-transparent smoked glass. This will create a more or less black bottom which on close inspection in sunlight shows CF weave at depth. I've done that finish on CF spearguns back in the day and it's kinda cool so I'll probably do that.
EDIT: oh yeah, the hull is also *SOLID* For cleaning the other night I had it hoisted off the sawhorses and had it suspended from the ceiling on ropes, still on the strongback. I was exhausted and left it hung overnight and came back in the morning to discover it had fallen--some of my crappy knots had come loose so the rear end was laying on the ground. The boat was unfazed. No dents, bending, damage or anything. It hit a sawhorse and dented the cheap pine on the saw horse but I couldn't find any dents or anything on my hull. I've taken out a lot of strongback sections already but the strong back as originally built was really heavy, maybe 140lbs. I don't know how light the hull actually is but I think it is quite light. We'll see--the WRC is like balsa, but it has some structural white oak which is super dense, and the bulkheads and transoms are laminates of WRC and marine ply so those do have varying amounts of denser materials.
