Northeaster
Senior Member
- Joined
- Sep 18, 2011
- Messages
- 265
- Reaction score
- Location
- Eastern Canada
Hi folks. Sorry to be longwinded....This used engine was keelcooled with dry stack. I added a heat exchanger off of V8 chev I believe. I likely have one of the hose connected wrong as when keel cooled it had an expansion tank and now just has the little one pictured above heat exchanger.
First sea trial on new boat build and engine overheated went to about 220F and I shut it down. Seawater coming out of heatexhanger was cool. Back at dock I added antifreeze (as I had just connected new hoses and filled as full as it would take at the time, cold) and tried running at dock. This time stayed around 160F. Tried on ocean under load and overheated again. Back at dock added more antifreeze as small expansion tank went low when running. When shut down air bubbles came up so thought maybe airlocked. It seemed promising, as after adding about a gallon of antifreeze, and running at about 200 or 210F I got a surge of warm / hot water out seawater exit - figured thermostat opened.... and temp dropped to about 160 and stayed there at dock...not under load though. Out again on ocean and quickly overheated with seawater still cool when overheating - there was no surge of warm water in seawater exit... When not overheating seawater was warmer. I suspected maybe a sticky thermostat.... or still airlocked if that is possible.....
Currently only running a temporary electric water pump to circulate the seawater, but it does put out about 3-4 gallons per minute.. And, I would think if it were not capable of removing enough heat from heat exchanger I would find that the flow of water was warm/ hot all the time, just not enough volume. As mentioned, it is cold when the temp gauge goes high, so to me it seems like the engine / thermostat/water pump is not circulating enough hot antifreeze to the heat exchanger to have the seawater take on it's heat....but I am fairly new at marine engines.
Please have a look at hoses / setup for obvious errors.
One thing I noticed. While running at dock with pressure cap off the small expansion tank. There was hot antifreeze coming intermittently from the small hose connecting it just below pressure cap to the water cooled exhaust manifold. It has been 3 years since dismantling hoses from engine to paint so I may not even have them going to proper places. To me it seams like that small hose would go from below pressure cap to an overflow tank of some sort.... but if I have it wrong where does the small hose from the manifold go? It is on a double fitting with a somewhat larger hose. It looks like its correct based on net pictures I have seen, but the stock engines have large expansion tanks..... my setup from a gas engine doesn't....will this work on a diesel or do I need a larger expansion tank?
I also noticed tonight that the small expansion tank was not level (seen clearly in both pics), due to a fairly stiff new hose connecting it to front top of engine, near temp sensor - it was on an incline rising toward the belt / front end of engine, so I used some wire to bring it down to level. Engine was cold, but this caused small tank antifreeze to run into block so I again added more antifreeze...
Leads me to another question - As there does not appear to be an overflow tank, like on cars, how do you know if you have enough / too much antifreeze in system, if adding either when hot or cold? Can you put too much, if so what happens?
PS sea trial otherwise went well, lots of power, hit 22 kts before overheating and no leaks in new aluminum boat after a week in the water....
