Crf
Discussion in 'Education' started by kaungsat, Jan 30, 2014.
  1. kaungsat
    kaungsat New Member
    how can i calculate coefficient of rolling resistance between the air bag and sand?
    Is this an inflated roller to move a heavy object?
  3. kaungsat
    kaungsat New Member
    we use air bag to launch the ship
  4. Ad Hoc
    Blow the bag up. Place a known weight on it. Place the bag onto the sand...then pull low down with a calibrated balance so when the bag starts to move, you have the load required to initiate movement = coeff. of friction. Since the load to pull is = W x coeff of friction. You'll have the Force/load (from the balance), then with the known weight (W) you can calculate the coeff of friction. As a good rough estimate, that's the best/quickest way.
  5. kaungsat
    kaungsat New Member
    thank you so much for your advice.
