Agreed Pro-E is fast, they halved the file size by going to binary so SolidWoks could not read in the files about 10 years ago. It is very capable with tapers and filleting. One interesting feature is how good is the tangency? If you export a tight tolerance file out and read it into Rhino (tight tolerance input) you will find the tangency is actually not quite as good as you might think!. Pro-E takes expressions pretty well too, in the sketcher, some 2D CAD stuff does too, an important feature for some of us.
In the real world it (tangency) is well inside manufacturing tolerances, but I have noted that the Rhino tangency can be tighter. Rhinos 'engine' is the NURB one from Integrity Ware.
The factor of 10 was noted when a shelving unit for a 21" CRT monitor (remember them!) bent 27mm instead of the 2.7mm predicted. I noted our original design was sufficient but had been reduced by the FEA specialists.....
