Cosine Wherry, Water Sculpture on the bulb of a submarine
Discussion in 'Hydrodynamics and Aerodynamics' started by mtumut, Jul 6, 2016.
  1. mtumut
    Likes: 1, Points: 0, Legacy Rep: 7
    mtumut Junior Member
    May I request from forum members to explain me , the cosine wherry design process ?
    I have WB 100 but I could not understand the invention .
    I can only see the wave crash on the bulb of a submarine elegantly and everything is so beatiful and better than whatever sculptors tries to create.
    I think Cosine Wherry have a shape like a submarine bulb where bulb pushes the water in to a sculpture form.
    As you can see I can see something but I cant explain.
    Please , may I please from you to invest 15 minutes to explain things ?
    Thank you,
    Umut
    Istanbul
  2. mtumut
    I thinked a little bit , there is a horizontal cosine graph at the WoodenBoat 100 and AFAIK,
    the displacement of the sections must follow that graph like a Napoleon Hat.
    Is it true ? If we give the volume every section , does the boat shape comes automatically ? I think I read the Colin Archer comment on wave theory and shape comes from mid section shape , dimensions and prismatic coefficients.
    When all inputs and volumes touch each other , boat comes to hand.
    I want to understand what is exponent which seems to me related with cp ?
    Do I understand correctly ? Can you please help ?
    ps. I thinked a little bit more and remembered front middle and back sections calculated indiviually , is it true ? Which equation used for each ?
    Thanks,
    Umut
  3. gonzo
    My understanding of the design, is that it is a proof of concept. The designer thought that he could use that cosine equation to design a boat. It is OK, but nothing ground-breaking.
