rustybarge
Cheetah 25' Powercat.
- Joined
- Oct 26, 2013
- Messages
- 533
- Reaction score
- Location
- Ireland
Hi All,
Just thought I would start a new thread on this subject rather than hijack Hastings Harry's diesel OB blog.
The Concept:
To convert petrol/gas OB to diesel fuel as a standby engine on a single screw 40' diesel trawler with only one engine; no petrol needs to be stored onboard and standby OB can use the main fuel tank.
About 60-70hp approx output to push at hull speed.
Large propellor to with fine pitch to give good grip in the water.
I previously proposed attaching a saildrive to an outboard leg, which mr Efficency quite rightly pointed out wouldn't work so well:
Then an outboard diesel conversion occurred to me:
What sort of problems do you think this project might face?
What size of petrol OB engine would be big enough to take strain of diesel conversion?
What sort of diesel pump and injectors would be the easiest to use?
Run a standard capacity at slow speed, or re-sleave to make smaller capacity?
The Concept:
. Quote:
Originally Posted by Mr Efficiency
Such thoughts have probably occurred to a few people, you have the issues of getting the right final gear ratio and propellor size right, and dropping a heavy engine on an outboard leg could create some serious balance problems ! But a big outboard leg should cope with the extra torque OK. The scarcity of diesel outboards shows little sign of changing.
[/QUOTE]Posted by rustybarge:
Maybe a better plan would be to get a very big capacity petrol outboard, sleave the cylinders to bring it down to say 1600cc/1.6 ltr capacity, and convert it to diesel. Deck the block to get 16/1 compression; no problem with block strength.
A fuel injection pump off a small Vw diesel car would work perfectly, and from memory would produce about 70-80hp.
This way the OB engine block would already be in a vertical position, and all the lubrication pumps and holes would have already be designed to operate vertically. The balance of the OB would remain unchanged as well, the steering and tilt remains standard.
Standard spares would still fit.
........I seem to remember a large v8 American engine was successfully converted from petrol to diesel, and sold in large numbers. It was available in the UK as a conversion for the landrover.
any ideas what large OB would make a good candidate for the conversion?
