Converting a Sketch Into a CAD FILE??
Discussion in 'Boat Design' started by DRD Boats, Apr 3, 2012.
  1. DRD Boats
    DRD Boats Junior Member
    I have a couple of sketches that I have drawn of some drift boat hulls and would like to get them converted into CAD files.... How do I do this and what would be the cost??
  2. TANSL
    Likes: 651, Points: 123, Legacy Rep: 300
    Could you give details or show a figure with what you mean by "sketch"?. Also need to know what CAD format are you thinking about: dwg, iges, dxf, .... I could help you with pleasure. Depending on workload, we should speak or not its price.
  3. DRD Boats
    It is literally a hand sketch with no dimensions on it
  4. TANSL
    Could you, please, scan one of the sketches and upload it on this forum? (attach the file to your response)
  5. bntii
    bntii Senior Member
    Oh gosh- its been too long but I have done it.
    Two ways:
    Software- The image is digitized by stint of software placing points on the sketch which become objects in CAD.
    Manual- the picture is imported and one simply uses it as a layer which is overdrawn by hand in CAD.
    I will take a look when I get out to the shop and see if I can remember how I have done it.
    If you are sitting at your machine with CAD loaded- try looking at the import menus & you may be able to figure it out.
  6. DCockey
    Likes: 611, Points: 113, Legacy Rep: 1485
    DCockey Senior Member
    What are you expecting the CAD file to be:
    - Scan of the hand sketch in a file with a format used by CAD software.
    - 2D drawing based on the sketch with faired/smoothed curves.
    - 2D drawing based on the sketch with faired/smoothed curves with curves reconciled (intersect where they should intersect, etc).
    - Design as 2D drawing based on the sketch from which a boat could be built.
    - Design as 3D math model based on the sketch from which CNC files could be generated for molds, etc.
  7. yipster
    yipster designer
    Was thinking the same, what is it for. Freeship forexample has an extra manual on how to overdraw this from a sideview (and top + front/rear view) into a 3d cad file
    When your sketch is drawn in perective fine, gives a good impresion but some dimension are needed going cad
    Best to do 3d I belive and have devellopable surfaces, stabilty and speed calcs etcetera at the same time.
    Just that or need construction plans? Make a SOR (statement of requirements) even for a drawing
    With only a little extra work and some mapping done you can make foto realistic various angle 3d pictures or with a camera placed in the 3d cad scene do a walktrue or flyby animation for presentation purpose, put a soundtrack in, cost be less than you expect. whatever, all depends on what you want.
    Can we see the sketch to satify our curiosity?
