combining Vinyl Ester and Polyester resin
Discussion in 'Materials' started by Kayaqua, Jan 20, 2017.
  1. Kayaqua
    Likes: 1, Points: 0, Legacy Rep: 10
    Kayaqua Junior Member
    I think it's probably not good to mix the two resins together but I have a small amount of vinyl ester and am wondering if it's ok to lay some fiberglass with the vinyl ester and another joining layer with polyester? Laminating a mold.
  2. ondarvr
    Likes: 685, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    You can blend them, it's not a problem.
  3. Kayaqua
    Thanks Ondarvr. I'll do just that!
  4. FMS
    FMS Senior Member
    You can blend the liquid polyester and vinylester resins? Any caveats?
  5. ondarvr
    Yes, they can be mixed together, you can buy blends of the two.
  6. Kayaqua
    Spblendid today's layup; Brown Vinyl and blue iso polyester. Works fine. The iso-spray poly is thinner than the older vinyl which is a good thing for me, but maybe the spray iso-poly on it's own is going to be a little bit runny.
