Am converting a 1970 Cary 28 to closed cooling. Previously was on Lake Erie and now going to saltwater in Florida. I am using a Sen-Dure 1250 heat exchange on 1985 chrysler 440's to convert to closed cooling. The thermostat housing has (2) 3/4 inch lines and (1) 1 inch line coming from it which is capped off since it was the recirculation line. I routed each of the 3/4 inch lines to the exhaust manifolds which then return to the heat exchange. Therefore, the cooled water from the heat exchange goes to the centrifugal pump (on the front of the engine), then through the block then out the thermostat housing through these (2) 3/4 inch lines which go to the manifolds then back to the heatexchange. I am using a sherwood G7 (1-1/4 inch) impeller pump for the raw water supply. The thermostat is 160 degrees opening temperature. I have set up both motors this way on the Cary and they both run hot. 180 degrees at idle and rise to 210 degrees with full power and therefore I slow down to cool them back down. Do I need to get a different thermostat housing which has 2 larger outlets? Anyone with experience with 440s and the Sen-dure heat exchange? Would appreciate any help.
Thanks,
Mark
Thanks,
Mark
