The construction of Graeme King's Kingfisher is ply (3 mm?) over a frame of stringers and bulkheads, not S&G. Its design has to accommodate the inability of plywood to curve in two directions at once, but it is a fine boat with near-competition performance. Its design pays more attention to ease of building and safety in the water than typical rowing shell designs. Kingfisher's hull is not glassed ASFAIK but the deck is reinforced with some fabric. The building of Kingfisher is described in issues 61, 62 & 63 of wooden Boat magazine; pdf copies are available from their web site - considerably cheaper than the plan set and adequate to get a feel for the process. Of course if you go ahead then get the plans which include full size templates.
The rounded hull of a strip-built boat helps to improve the limited strength of strips, but strippers are almost always glassed inside and out for proper strength, which adds significant weight, not to mention rigging. I built a partially-stripped canoe with laminated ribs and a ply bottom that is not glassed, so it can be done; it is exceedingly light, but demands careful handling.
Since the construction is ply over stringers the panels would be cut to fit, so I don't expect the plank developments (needed for S&G) are provided in the plan set. I don't think it would be a big deal to add another stringer partway up the sheer planks to introduce more shape to the topsides. It would have a slight effect on behaviour in the water but not much, you could offset that by moving the chine stringers inboard by enough to keep the waterline beam the same. A simple way to judge the effect on appearance would be to make a model.
