Cavitation higher than expected at very low speed
Discussion in 'Hydrodynamics and Aerodynamics' started by John Rivers, Oct 9, 2022.
  1. John Rivers
    Likes: 5, Points: 8
    John Rivers Junior Member
    https://phys.org/news/2022-01-low-speed-impacts-liquids.html
    "They showed that even at speeds as slow as one meter per second, the impact can decrease the local pressure sufficiently to cause cavitation. This comes about because the liquid is slightly compressible, and so the impact creates waves of large pressure that reflect from the surface to form negative pressure regions.
    Only objects that contained an edge led to cavitation. The team saw no such effect when they investigated the impact of a 20-millimeter-diameter sphere, for example."
  2. baeckmo
    Likes: 836, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    These findings are fully consistent with the "classical" theory for pressure transients ("water hammer").
    John Rivers likes this.
  3. Doug Halsey
    Likes: 218, Points: 53, Legacy Rep: 160
    Doug Halsey Senior Member
  4. John Rivers
    Likes: 5, Points: 8
