abdulrahman
Junior Member
- Joined
- Mar 17, 2022
- Messages
- Reaction score
- Location
- Turkey
Hello everyone, so I am working on a catamaran boat which serves the purpose of cleaning a lake from it's plastic waste etc... basically a lake cleaning robot to be more clear. And after designing the model i now want to find the power needed to power up the system, I did research about it but all i was able to find were not as beneficial to me since it's not in the metric system. i want to find the power equation to calculate it for this hull with dimensions of : 100cm length, 40cm height, 70cm width. And i would like to also ask how am i supposed to do quantitative assumptions for such a thing?
some other things that i would love to get some insight about which are :
how can i determine the thickness of the material am going to use ? " material that i am thinking of using is PETG with an average density of 1.27 g/cc.
how can i determine thrust of the motor i will choose " after determining the power"
(below is attached the design and also some calculations that i once tried to do but then found that i cant be using inches and then continue with metric system, i should be sticking to one system for the accuracy of these calculations)
