I'm considering a grainger Raku project, but would like to push up the stiffness and strength of the bridge under the mast as it's the most hard working part of the structure. Any views on adding a carbon cross beam to the design?
Note: This feature may not be available in some browsers.
I don't know anything about Raku.I'm considering a grainger Raku project, but would like to push up the stiffness and strength of the bridge under the mast as it's the most hard working part of the structure. Any views on adding a carbon cross beam to the design?
That does not have to be true, there would have to be a study of the structure to see how that extra structure varies the stresses distribution. It could happen that stress concentration occurs in some area but those stresses do not have to exceed those who experienced the points of the original structure. In any case, since we are adding structure, let's add what is necessary at those stress concentration points. But, imo, a pillar, if it is possible to place it or reinforce the existing one, will always be better than a transverse beam.Stiffening a small part of a structure creates concentrated stresses and leads to failure.
I'm considering a grainger Raku project, but would like to push up the stiffness and strength of the bridge under the mast as it's the most hard working part of the structure. ..
You have to study how the structure is at that junction of the foot of the mast with the pillar that supports it. At that point they can produce, as designed by the designer, not only a compression force that is transmitted to the keel by the pillar, but, perhaps, important bending moments and efforts transmitted to the deck. But it is not sensible to say anything concrete if we do not know the configuration of the mast and its union to the keel and deck.The mast is supported by a pillar, and I guess this would be bearing only compression loads.
The structure does not need to have the stresse spread out..., it is the structure that must spread these stresses properly.The structure needs to have the stresses spread out
I don't know about Raku's but Schionning Wildernesses use large layups of unis in their beams. Old Multi has the layup of a Schionning like cat of about 13 metres in his structure thread. I have seen a friend lay up a heap of unis into the top of a routed out balsa duflex panel. The unis can be put on top of the bulkhead (which is a shear web) and laminated on the underside of the deck. There are more unis on the top of the bulkhead than the bottom - because the glass does not like compression as much as tension.
Phil
