Can you name my hull type?
Discussion in 'Powerboats' started by YeaBouy2014, Oct 30, 2014.
  1. YeaBouy2014
    YeaBouy2014 New Member
    Hi all,
    I have this 21ft hull. I have been told that it may have come from the British Virgin Islands (BVI). Ive looked about and asked about and cannot get an confirmed answer. Doe anyone have any ideas what type of hull this is??
    Thanks in advance for any thoughts...
  2. Mr Efficiency
    Well, it is obviously a planing type of hull, but I suspect you want to know what the make and model are.
  3. gonzo
    What do the Hull Identification Numbers in the stern say?
  4. YeaBouy2014
    Yes, am trying to ascertain the make/model. Checked for HIN but nothing to be found. The transom has been rebuilt.
  5. PAR
    The transom is not the only place the manufacture is required to place a HIN. There will be another on a structural element within the boat, not plainly or casually seen, but still fairly easy to find, if you look hard, often with an inspection mirror. Engine beds, major longitudinal stringers, major deck beams, the stem, the keel, etc. are all places to look. Lastly, no respectable repair shop will cover the HIN, doing a transom recore job. Even if the transom skin is completely trashed and replaced wholesale, the HIN is cut out and transferred or replicated on the new skin. This should make you question the work under the skin that covers the HIN, as it just might be a stolen boat, looking for a new home.
  6. gonzo
    If the title doesn't have the information and there is no HIN, I would guess it is a stolen boat. It looks like it could be a Mako 23.
  7. YeaBouy2014
    Yep, it's def a Mako 21. Will investigate further to find the HIN. Hopefully it may give more info in the year. It was in a real mess a year ago - many people said I was crazy to restore, but I'm happy with the end product. Thanks for your advice.
