Calculating KG
Discussion in 'Stability' started by ed198, Sep 24, 2018.
  1. ed198
    ed198 Junior Member
    Good day...an amateur here...I calculated the GM of my 25ft sailing boat by performing a inclining experiment ...i am now after calculating KG but not sure how to do this...can someone shed some light?
    Ed
  2. rwatson
    rwatson Senior Member
    It will depend on the size.
    Small, put it on a truck and go to a weighbridge
    Big, Get a load cell on a crane and lift it
    Tiny, Put it in a pool and measure how high the water goes up
  3. TANSL
    Likes: 943, Points: 123, Legacy Rep: 300
    @rwatson, I think he's talking about calculating the KG, not the weight of the boat. It is possible that to calculate the KG he needs to do something else.
    Imo, to calculate the KG should make a relationship of the weights and their centers of gravity and calculate the resultant.
  4. TANSL
    I think I have misinterpreted the question of the OP because, in saying that he had made the stability test, I assumed that it was already the ship's KG at the time of the test. In that case, he only had to add the missing weights and deduct the ones that were left over, with their centers of gravity, to calculate the KG in the final condition he wanted to study.
    If what he asks is how to calculate the ship's KG in stab test time, he should use the following formula :
    KG = KC + Rmt - GMc * Cos (teta)
    Rmt = transversal metacentric radious
    GMc = GM0 - Free surfaces correction
    teta = heeling angle at test.​
  5. rwatson
    I understand. I saw Kilograms, not the variable. Thanks.
  6. TANSL
    Yes, you're right, it could be interpreted that way. Maybe I've gone too smart.
  7. Heimfried
    Likes: 153, Points: 43, Legacy Rep: 37
    Heimfried Senior Member
    If this was the usual inclining experiment ("Betriebskrängungsversuch"), the displacement of the boat was necessary for the calculation of GM. Therefore I think, the TO is looking for the KG (Keel - CoG) to locate the VCG.
    TANSL likes this.
  8. Heimfried
    Hi Ed,
    calculation by boat parts and their location is laborious but easy in case of a boat under construction but often not really possible in case of older boats with partly unknown structure, density of parts etc.
    If your boat is not large, may be you can do an inclining experiment in air:
    Document
    Correction
  9. Ad Hoc
    Likes: 1,950, Points: 113, Legacy Rep: 2488
    Which suggests he was either given the displacement, at inclining, or he must have a set of hydrostatics for the vessel.
    If given, he can ask, or if he has the hydrostatics, he can just look at the hydrostatics as it will, or should be, tabulated in them.
  10. ed198
    ed198 Junior Member
    Hi i did the inclining experiment and therfore know the displacement of the boat since we recently hauled it...i am after KG to find the centre of gravity ...i have calculated GM...
  11. ed198
    ed198 Junior Member
    Yes exactly...
  12. Ad Hoc
    So your displacement is via a physical weighing..not via hydrostatics?
    Do you therefore not have a set of hydrostatics for that hull?
  13. ed198
    ed198 Junior Member
    yes the boat is in the water...we recently hauled it and know the weight..
  14. Heimfried
    Ed, did you find the paper about the determination of KG by inclining experiment in air, I linked above?
  15. ed198
    ed198 Junior Member
    Thanks yes but boat is in the sea and inclining experiment was done in the sea...
