Will Gilmore
Senior Member
- Joined
- Aug 29, 2017
- Messages
- 1,113
- Reaction score
- 536
- Location
- Littleton, nh
Doesn't your response sort of support the arch just for solar panels idea?I would first need to know what it is you are trying to do.
Simply mounting solar panels doesn't cut it.
I can tell you I would consider flexible panels instead, mounted directly to an existing deck surface.
Although, finding an area with unobstructed exposure to the suns rays would be a priority
as even a rope across a panel can result in significant voltage drops and inefficiencies.
This example is bulky and overkill for a high wind structure to secure solar panels. But an arch offers the best unobstructed exposure to Sunlight. The problem with sailboats and solar panels is that sailboats have great massive big wedges of sunblocking cloth sticking up in the air.
As far as hurricane force winds on an arch, the biggest problem will be the panels themselves. I suggest installing them with an easy snap-on snap-off bracket and plug to remove quickly when a big storm approaches. Hurricane force winds can sneak up on you with a sudden, but short bust, but you're much more likely to see it coming from miles away and the Sun will probably be hiding before then, so stow your panels below. Your panels will thank you and so will your helm.
