I can’t figure out how to practically build a fiberglass composite panel with a recess for a window.
The panel is 1” thick, 6lb density foam core with 36oz glass on each face.
The window design would be the kind were you subtract the thickness of the window and adhesive from the panel at the mating surface to create a flush window on one surface when the installation is complete. A modern, frameless, flush window.
The question is, how the heck do I create this little rebate for the lip the window rests in from fiberglass and foam??
if I use a router after building it, there is no glass on the lip. If I create the exact shape out of foam, then try to carefully glass the lip while building the panel, it’ll be impossible to get the glass to sit down in the 90 degree angle of the lip.
How is this done?
How is this done?
