UNCIVILIZED
DIY Junkyard MadScientist
- Joined
- Jun 15, 2014
- Posts
- 166
- Reaction score
- Location
- Land O' the Great Lakes
On a lot of bigger multi's, especially tri's, it's common to bolt the traveler track to one of the rear main beams. Which, I would think that having so many bolts in a carbon fiber structure would weaken it a good bit. Since as a general rule it's not smart to bolt fittings onto carbon spars, or machine exit holes for lines into them, etc. So how do you get around this with travelers?
Is there enough extra reinforcement built in to account for the bolts forming a "tear here" line? And or, might you build in a slab of G-10 to bond the bolts into? Speaking of which, are nuts & washers used on the fasteners, or are they simply epoxy bonded into the beam's structure? How about backing plates?
