philSweet
Senior Member
- Joined
- May 2, 2008
- Messages
- 2,983
- Reaction score
- 690
- Location
- Beaufort, SC and H'ville, NC
Some comments on issues discussed above.
Regarding fuel separation. There are practical reasons to worry about this. While each batch of gasoline departing the fuel depot should be stable for long periods on it's own, it turns out that if you mix two stable gasolines that get there differently, the resultant mix is not necessarily stable. And it needn't be you who's doing the mixing. An independent service station which procures from multiple vendors can end up with a separable mixture in their supply tank. Mixing different grades of fuel that get there with exactly the same stabilizers can also become unstable. For instance, mixing E05 and E10, both from the same brand and containing the same stabilizers, may not result in a stable mixture. And that can happen easily enough when you fill your vehicle. So for vehicles that may not get used for a while, sticking to one fuel source can significantly reduce the risk of problems. Long term, separated moisture can leach out all kinds of salts and other solubles from the fuel and additives.
The issue with water in ethanol gas is counter-intuitive, to say the least. There are a huge number of studies published on the subject over the last 30 years. Adding water can reduce the corrosive tendencies of ethanol gas a lot. In some cases, by orders of magnitude. To whoever mentioned they were washing the alcohol out of their small engine gas, any benefit was probably from the water left behind in the gas, not from removing the ethanol. If they had effectively flushed the alcohol out, the resulting gas would have an octane rating in the 60s and the motor would run like crap, if at all. But this is all very sensitive to the exact fuel chemistry and water chemistry, with impurities needing to be quantified to ppb accuracy. There are several corrosion studies that consider seawater ingress and condensing coastal air in ethanol gas fuels.
There seems to be a divide on the perceived effectiveness of fuel quality enforcement. My American view is that there isn't any. We just let the big oil refiners and motor companies sort it out themselves. There is no way to compare gas historically because the understanding of what can be sold as, say, 87 octane E10 changes from week to week. There is no testing, no enforcement, and no real liability associated with selling bad gas. Fraudulent and adulterated fuels are very common. When consumers switch away from sketchy gas stations, the owners have to find better supplies.
