Boat structure designing tool / detailing tool
Discussion in 'Software' started by slenay, Oct 28, 2012.
  1. slenay
    slenay New Member
    Hi all,
    Does exist out there a software which from a hull designed takes over to detail the structure and the building of it and then complete the weight and the stability studies in order to pass on the complete spec to a shipyard?
    Any free stuff?
    Are the classic CAD softs lead in this segment still?
    Kind regards,
    Sylvain
  2. TANSL
    Likes: 683, Points: 123, Legacy Rep: 300
    Many years ago in my country was a devout farmer who, while he went to the holy offices, the angels of heaven plowed his field. The blast was so huge that it was declared a saint by the Catholic Church. His name is "San Isidro the Farmer." Unfortunately that's not happened again anymore. Never have become angels to help anyone else and, when you need something, you have to get it by working with your hands (or/and your brain).
    Regards.
  3. gonzo
    Likes: 1,619, Points: 123, Legacy Rep: 2031
    The short answer is: no. If someone were to design software like that it would be very expensive.
  4. alidesigner
    Likes: 6, Points: 18, Legacy Rep: 93
    alidesigner Senior Member
    you can do you hull shape and basic stability in freeship - free
    you can do advanced stability in a spreadsheet - open office - free
    you can do 2d drafting in draftsight - free
    you can do 3d modelling in alibre - cheap or creo 3d Direct - free (these will give you some weight data)
    You have to know what you are doing and its not an efficient way to do it but it is possible. If you are designing steel or aluminium then your biggest challenge will be to flatten the hull for free, but you can always develop it manually in 2D cad.
  5. rwatson
    Likes: 477, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    Freeship will 'flatten' the developable surfaces for free -( unrolling )
  6. alidesigner
    What about surfaces that are not developable ? and will it let you export it? I dont use it but the way I read the Delftship web site you can only view the plate expansion in the free version, but not sure about freeship.
