Boat identification help request
Discussion in 'All Things Boats & Boating' started by jvh100, Aug 15, 2014.
  1. jvh100
    jvh100 New Member
    Hello everybody. I would like to ask for your assistance in helping to identify my boat please.[​IMG] It was built in the United Kingdom but have no idea by whom, or when.
    the stern is a double ended type with the outboard sitting between the two ends so to speak. Any assistance would be very much appreciated.
    Many thanks,
    John.
  2. Grey Ghost
    Likes: 9, Points: 0, Legacy Rep: 94
    Grey Ghost Senior Member
    Can you post a photo from behind?
  3. jvh100
    jvh100 New Member
    I don't have one available at the moment, however, i will take one and post it. In the meantime, this one may assist?
    Many thanks for your reply.
    John.
  4. PAR
    That isn't a double ended boat, but a transom stern, with a cut for the well. Frankly I see no reason for this "innovation" other then to be difference and make construction harder, plus decrease her performance abilities a tad. She looks to have a early skiff hull, which is essentially a flat bottom boat with rounded bilge turns and a moderately fine entry. Her buttocks don't appear to "tuck up" much, so she'd probably be able to plane off with enough power. On a boat that size 15 HP would get the job done (full plane mode), but she wouldn't have much reserve, so 20 HP would be better. This assumes she's not overly heavy. As to what she is, well who knows without a HIN or other identifying marks/builder's plate, etc.
    If that was my boat, I'd be inclined to make the transom conventional and gain some usable cockpit space.
