Barge Stability
Discussion in 'Boat Design' started by maritimeman, Mar 2, 2023.
  1. Ad Hoc
    Likes: 1,936, Points: 113, Legacy Rep: 2488
    Rather than just stating..it is wrong....you should state why it is wrong.
    Otherwise, it means nothing.
  2. TANSL
    Likes: 930, Points: 123, Legacy Rep: 300
    Ad Hoc, admired professor, I am not going to explain to you what you know perfectly well. If you understand something in that paragraph, and if it sounds good to you, explain what you understand. I cannot explain the why of something that, as I say, I do not understand. Once again, when you intervene, I have to say that I will not continue arguing with you through puns, which you use to put down your opponent, and which never add anything to the conversation. Should I also, in your opinion, justify this statement? Well, I won't.
  3. Ad Hoc
    Aaaahhh...ok, so your MO..is to criticise and attempt to belittle others, but not to offer anything worth while to the OP et al., nor answer the question or points you attempt to raise as being incorrect.
    Ok..gotchya.....just background noise..!!
    TANSL likes this.
