asymmetrical fin
Discussion in 'Boat Design' started by phum, Nov 4, 2010.
  1. phum
    phum Junior Member
    Hello all,
    Where would I find a drawing/ offsets for a asymmetrical fin section?
    Peter
  2. PAR
  3. phum
    phum Junior Member
    Now I have too many choices, What would be a common section used?
    Peter
  4. PAR
    Foils sections selections are based a several variables. What is your target Reynolds number range?
  5. phum
    phum Junior Member
    chord length .5 Mt.
    speed 3 Mt. a second
    Renolds number approx 100,000.
    Does that sound right?
    Peter
  6. PAR
    Okay, now what do you want this foil to do? It's application?
  7. phum
    phum Junior Member
    one of a pair of bilgeboards.
    Peter
  8. PAR
    That's not telling me much. What level of preformance do you desire? What make, model and year boat? Are there specific needs or issues you're looking to solve? What where the previous sections employed and why didn't you like them? Etc., etc., etc.
  9. phum
    phum Junior Member
    I am looking at replacing an existing lifting fin with 2 bilgeboards. The object of the exercise is to free up floor area in the cabin. lifting bilge boards would be built into bunks so floor area will be clear. The main reason for seeking a efficent section is minimise size and maximise lift.
    Peter
  10. PAR
    Well you still haven't told me much, so I'll just offer up some sections that preform well at low Reynolds numbers and you can research them and pick the one you like.
    Naturally, the first one would be the bench mark E387, next on the list would be the FX 63-137, followed by the SD 7003 and SD 7037.
    Then again you can fall back on one of the NACA 63 series like the 63-209 or try the Selig S3021.
  11. phum
    phum Junior Member
    Thanks very much for the info.
    Peter
