I've read that runners under a flat bottom jon boat:
2. I can't see how three or four 1x3 runners under a flat bottom can protect against rocks. I can see them protecting on a flat concrete boat ramp but rocks are bumpy and would hit the plywood bottom before they hit the 1x3 runners.
3. I think number-3 is valid since I can see where 1x3 runners under a plywood bottom can help to secure things inside of the boat.
4. Cons are: Can disrupt water flow to the prop, impedes turning boat on sand, hinders covering bottom with fiberglass.
Mainly number-1. Do 3/4"H x 2-1/2"W runners under a flat bottom jon boat really help with tracking straight? When not planing, it seems that just the sides would keep the boat tracking straight. Do 3/4" high runners really help tracking while planing?
I'm wondering if the cons out weigh the "pros".
- Helps with tracking straight.
- Protects the bottom from rocks.
- Helps with securing things inside of the boat.
- Has several cons.
