Anyone know where to buy this extrusion?
Discussion in 'Metal Boat Building' started by Jamie Greenfield, Feb 7, 2018.
  1. Jamie Greenfield
    Jamie Greenfield Junior Member
    Rough dimensions are 2.5 x1 inch.
    Thanks for any info
  2. PAR
    Welcome to the forum.
    There are several aluminum extruders online and they have a host of various profiles for you to look at. I know this is a pain in the butt, but after an hour or two, you should find one. Additionally, you might try a metal fabricator, who may have books with these same profiles and you can just flip through until you nail it down.
  3. Jamie Greenfield
    Hi PAR,
    Thanks for your reply. Unfortunately i have already done what you are suggesting and did not have any luck - hence the post here. I have seen others with this extrusion which i dont believe to be a custom order but who knows maybe it is?
    Thought it was worth a shot here among boat friends. Maybe someone has seen it before?
    Cheers
  4. gonzo
    Likes: 2,263, Points: 123, Legacy Rep: 2031
  5. Jamie Greenfield
    Doesnt have to be exact but something similar. 3/16 or 1/4 wall. Approximately 2.5x1 with the smaller upstand.
  6. gonzo
    Check the last link
  7. Jamie Greenfield
    Very close but not quite
  8. Barry
    Likes: 627, Points: 113, Legacy Rep: 158
    Barry Senior Member
    What is the application? Is the inside width between the upper and middle piece 1 1/2 inch?
  9. Jamie Greenfield
    Hi Barry, Not sure on inside width exactly but 1-1.5" would be fine. Application is planing/lifting strakes on aluminum jet boat. Currently using 3x1 angle but it's getting squashed flat a little too easy. The extra upstand would stiffen it a lot.
  10. Barry
    Barry Senior Member
    I would just buy a 3 x 3 by 3/8 or 1/2 inch and cut one side down to the 1 inch if the 1 x 3 has proven it to be the best profile for your boat. We normally purchased 3 x 5 as we had a 7 foot chine with 12 degree deadrise so we wanted a wide flat turned down maybe 10 or more degrees. So we cut the 3 inch side down to suit.
  11. Jamie Greenfield
    Yes i have thought about going up a wall thickness but it can already be quite tricky to form up in the bow because the boats are so short the curves are quite tight. Also not keen on the labour to rip a section off every piece of extrusion on every boat. That and weight. If i can find the pictured extrusion it would be better for what i am doing.
  12. Steven Lee
    Steven Lee New Member
    Hi, I am sure this aluminum extruder, Home https://www.hugh-aluminum.com, can produce your product, but they seem to be a manufacturer, so not sure if they deal with retail orders, but you can chat their online agent. Cheers
