There's no best angle. The sides can be plumb, though this makes the ride wetter, it is easier for some to build. The sides could be quite dramatically angled, which can be a little harder to build, but it'll be drier and will offer greatly increased volume improvements, as the boat's PPI goes up with loading.
More importantly than the angle, is how much twist the side panels have, at least in terms of building ease. Maintaining a consistent angle makes the boat easy to plank. Making the angle vary (twist) can offer more deck space and to most is a lot prettier.
Maybe it would be best to tell us what you're doing, as this question is so basic in nature, it makes me wonder about having sufficient skills to design (and engineer), even something seemingly as innocuous as a jon boat.
He wasn't being condescending; he was asking pertinent questions and pointing out that your question was basically a clueless one. Face it: if there were an all-inclusive 'best' angle, every jon boat out there would incorporate it.Umm, wow, have built several small boats, I was simply asking opinions because I see different plans with different angles, But thanks for being condescending. And yes, I am building a simple jon boat, sorry to start such a simple conversation amongst pros!
The most reasonable answer to your question is another question: "best angle for what?" Maximum load capacity, driest ride, ease of building, most attractive... every boat plan is a compromise, that reconciles conflicting parameters.
And I could definitely have been more diplomatic in my response. My bad.It was not a "clueless" question, Im trying to decide what angle to make mine, I know what I like as far as looks, but was just seeking to get opinions from others on what they like pertaining to the things you mentioned, load, dry, ease of building. Though, ease of building doesn't matter much as the angles don't scare me. I guess I should have clarified my question better.
If we mean by "initial stability," the value of the initial GMt, it does not depend on the angle of sides, but the waterline inertia at the time, and some other things. So, msaxthon, you need not worry, for now, the "initial stability"However, if you want maximum initial stability for the beam, slab sides are better.
Often people do not want a lecture but a simple answer.
And I could definitely have been more diplomatic in my response. My bad.![]()
Don't mistake PAR's bluntness and lack of obfuscating pretty language for condescension... he's willing to go out of his way to explain and inform, and is one of the best resources for amateur builders I've run into online. I've learned a lot from him - and he also happens to design boats with a nice blend of looks and practicality.
As stated above in different words; form follows function.
You will get more detailed advice if you will post a SOR (statement of requirements) which is to establish the intended use of the boat and the conditions in which it is to operate, the size of the intended engine, the anticipated load it is to carry, the speed that you wish to achieve, whether you will need to move around in the boat to play a fish, will you use an elevated swivel seat?, and a few more things that ultimately dictate the design features of the boat.
Almost none of that is much concerned with the flare angle. It is somewhat incorrectly assumed that flare is necessary to increase the roll resistance of the boat. It does help but not as much as one might imagine without doing the actual math. Most observers tend to believe that a boat must have some flare, so if you ever intend to sell the boat then make it look like what the buyer perceives to be necessary. On average Jon boats often have something on the order of 14 degrees which is roughly a bevel of one on four. That is about the same angle that the transom should have in order to accommodate the motor.
None of your replies have any intention of a condescending nature. This forum has thousands of members and many of them are very knowledgeable as well as admirably generous. Please do not take some of the straight talk as an affront to your intelligence.
