Good Morning,
I have a 70's Albin Ballad:
BALLAD 30 (ALBIN) sailboat specifications and details on sailboatdata.com http://sailboatdata.com/viewrecord.asp?class_id=1072
that I am going to be cruising with next year. She is fairly sensitive to weight in the bow and I want to have an all chain rode. My plan is to locate the chain in a locker near the front of the keel and make the deck penetration just fwd of the port side fwd chain plate penetration. I will drop the chain down through an ABS pipe and bend the pipe slightly into the center of the locker more amidships. From there is would be only a few feet more through the salon to move the chain into the bilge if I ever do a long ocean passage and want the bow even lighter.
Here is a plan view with the yellow spot indicating the location of the proposed deck penetration:
Where this chain will slide back and forth over the deck, I am thinking of just glassing in a hardwood board on the deck and then epoxy cover it with something like Dynel or Xynole . Thoughts?
Thank you all for the support on this project.
