Aluminum pilot house window question
Discussion in 'Boatbuilding' started by astglenn, Mar 10, 2015.
  1. astglenn
    astglenn Junior Member
    Greetings and thank you in advance for your assistance.
    I am building a pilot house on a 21' ex USCG aids to navigation boat. I am to the point of fabricating how I will install the glazing. I would like to consider installing 1/4" Laminated Glass into the openings for front and side windows. The largest of the windows will be 2'0" x 2'6". I purchased a sheet of 5/16" Lexan MR 10, and just cant see how it would ever stand up to wipers in a marine environment, so I ditched the idea for glass instead. I now own a really expensive 4x8 sheet of nice plastic.
    I would prefer to weld in a stub fin (Cut out panel sheet) around the inside of the window openings with .250" aluminum and then use a rubber beaded "weatherstrip" type mounting for the glass. I have also looked at the Diamond Sea Glaze windows with their flanged perimeter frame and backing ring. Weight is a concern.
    My question is, are the "Weatherstrip" type of mountings suitable and burly enough to hold the glass in place under marine duty?
    I appreciate any insight.
    Here bis a picture of the "Weatherstrip"
    Thank you
    Glenn
  1. John McCrary
  2. Asa Hammond
  3. renleo
  4. mariobrothers88
  5. AdmiralShellfishCo
  6. isslam akkilah
  7. Mark Rush
  8. fpjeepy05
  9. Deering
  10. River Ratt
