Alternative to marvelous Buccaneer 24
Discussion in 'Multihulls' started by Gary Baigent, Apr 18, 2010.
  1. oldsailor7
    oldsailor7 Senior Member
    Lookin' good Gary.
    Perhaps the humidity (read "Rain") is helping the ply to conform more easily. :eek:
    Fascinating stuff. Keep going.
    Paddy. :D
  2. Cheesy
    Likes: 12, Points: 0, Legacy Rep: 189
    Cheesy Senior Member
    very cool looking boat, will you be making plans for this available?
  3. Gary Baigent
    Gary Baigent Senior Member
    Wait until I finish it Cheesy, because I keep making changes as I go along, but will redraw it later; then I'll have the altered dimension figures plus weights for all the components, main hull, beams, floats, foils etc.
  4. captainsideburn
    Likes: 3, Points: 8, Legacy Rep: 23
    captainsideburn Junior Member
    I've been holding my breath for more pics :rolleyes:
  5. Gary Baigent
    Patience Captain, more coming soon - ps: didn't you like the wing mast??
  6. captainsideburn
    I thought you were working on your boat as I haven't got any message about the wing mast!
  7. Samnz
    Likes: 4, Points: 0, Legacy Rep: 47
    Samnz Senior Member
    nice work Gary.
    Do you think it will be faster than Groucho?
    Whats the main hull flare for?
  8. Gary Baigent
    hi Sam, the flare is to provide a wider support base for the single main beam, it will be reinforced with carbon inside and out - and also gives the (foolish) illusion of extra space below cabin. Also in the small flared area forward of the beam I can make two shallow bins each side for the lightweight anchor (from your work place) and the warp; similar setup as on Groucho.
    Sid should end up lighter proportionately to Groucho with similar proportional sail area - but Sid will have a larger chord wing mast - so who knows?
  9. oldsailor7
    Gary. I hope the weather is being kind to you and also to Jamez for you two building your Tris. It's been sunny and dry here for the last few days, but unfortunately I am not building a boat. I wish I was. I always found building a boat was such a creative activity. :D
    Never mind ---the better weather is only a few weeks away now.
    But then you will want to go sailing. :eek:
  10. Gary Baigent
    It's been like a mini Pakistan here, no, that's not true, but it has been real soggy - although I've shaped the two bunks for Sid and will fit them when the sun eventually shines again. I've been reshaping friends rudders in the meantime. because in the equinoctial winds and rain we've been having, their rudders have failed, either stalling out because of not enough depth or ripping off the transoms during savage gybes. Flash Harry buried four times up to the mast base in wind against tide seas ... so I need to put some reef points in. Insane not to have them in the first place.
  11. Gary Baigent
    In between squalls and thunder ........
  12. Doug Lord
    Doug Lord Flight Ready
    Impressive-very good looking.....
  13. oldsailor7
    Gary.
    That looks magnificant. Is that glossy finish Resin or Polyeurethane.
  14. captainsideburn
    woo, the wait was worth it, looking great.
    i'm just curious on your take on the skinny stern, most trimarans have a wider stern, as I understand to mitigate hobbyhorsing... is the idea that the foil supported rudder does this instead?
  15. Gary Baigent
    Just epoxy oldsailor - the photograph makes it look better than it is. Actually a squall came through while I was away and lightly pockmarked it. Doesn't matter, sand it later. I'll be painting the interior offwhite before the deck goes on.
    I've always liked finer sterns capt n. because the wake is smaller and cleaner - also the inverted T rudder foil stops the stern, and the platform, from misbehaving.
