Philippe Lapere
Junior Member
- Joined
- Aug 14, 2018
- Posts
- 16
- Reaction score
- Location
- South Africa
Hi everyone,
I’m designing and building a prototype sailing beach catamaran and would like to get your opinions and recommendations: its going to be 20 ft with 8’6” beam, beachable, capsizeable and relatively light, with very good load capacity for cruising with up to 6 people, yet is still fun and relatively fast to sail (particularly when loaded a bit lighter and pushed). It would be somewhere between a supersized Hobie Getaway and a lighter, less powerful Hobie 21 Sports cruiser.
I’d also like to be able to launch through fairly large surf (I live in Port Elizabeth in South Africa and plan to do coastal camping trips where sea conditions are frequently challenging).
Some functionalities that I’m planning or considering to incorporate into the design:
· Mounting for an outboard motor, maybe between 4-9 hp
· Self-tacking, roller-furling jib, easily reefable mainsail, and a furling gennaker sail
· Foreward netting area (for sitting / lying on in lighter conditions)
· Potentials: windvane autosteering, rowing oars (doubling as righting pole and mast step pole), flip-out wheels, (nothing is off the table
On the topic of design: I’m not a naval architect (I’m a Mechanical/Industrial engineer with manufacturing experience), and I’m not under any illusions about the gravity of the challenge of designing and manufacturing a sailing boat, hence this post for advice. I’d like to design something that’s unique and different so I’m not keen to purchase plans, or modify existing an boat.
I’ve done lots of research and have seen a fair share of red flags and failed projects by being over-ambitious or misguided, so I’d like to avoid such pitfalls by sticking within the realms of existing designs, and building on solid principles and practices.
I’ve therefore finalized the design by benchmarking extensively, and sticking relatively close to existing cat designs, but maximizing the necessary parameters (most notably hull volume).
Out of interest, I’ve calculated the prismatic coefficient using Excel by modelling the rocker, waterline and cross-sections mathematically and integrating over the length to calculate volume.
I’ve designed the hulls in Autodesk Inventor (using the mathematical formulas for the rocker etc as a guide to create the shape). See attached CAD screenshot, as well as pics of a 7:1 scale model of the boat, created by printing out the bulkhead sections and covering with paper and superglue.
Some questions I have that I’m hoping can be answered:
- A concern is the hulls causing too much windage, at their widest point each hull is 420mm wide and 660mm tall (front is around 600mm tall and rear 400mm) – this is 25% additional windage than a Getaway, 40% more than a Nacra 5.5 (!). What effects can I expect from this? Thinking of slightly raking the bows back to reduce windage at the bows (and for the cool looks lol), worth it?
- The Prototype manufacturing method I’m using is to CNC cut 13 pre-laminated bulkheads out of 16mm 60kg/m^3 density PVC sheet based on the CAD drawing, then mount the bulkheads onto a strongback, then create the hull by “strip planking” using strips of the same spec PVC (pre-laminated on the inside), then laminate the outside (3x layers 160g woven fiberglass and epoxy), sand, fill, flip, same strip planking on top, and voila! Any thoughts on the laminating schedule, is there a recommendation for how many layers of which spec fiberglass to use for a beachcat of this size?
- For leeway prevention, I plan to mount pivoting leeboards on the inside of the hulls (so on the side of the hull, under where the trampoline joins the hull). Do you think that there’ll be considerable interference between the hull wave and the leeboard (so between the board and the hull)? I’d like to avoid the complexity of the centreboard boxes, and hoping it’ll be worth the performance compromise.
- For the original protoype I’m going to use the mast, sails, rudders etc from my hobie 16 to test – hopefully soon therafter add a furling genoa for some additional power - any thoughts on the performance I can expect, particularly when loaded with 6 people? I know it’ll be underpowered compared to the 20ft sport catamarans that are out there, but that’s not my goal – I’d like to make a boat that’s pleasurable to sail on that has a high load capacity, without completely tanking sportiness (like a Tiki 21 would)
- Any other thoughts or recommendations? Thanks!
