a question about gluing
Discussion in 'All Things Boats & Boating' started by planeman, Jun 28, 2009.
  1. planeman
    planeman Guest
    Kindly forgive what must be a rather simple question, but why
    are wooden masts glued rather than fastened. I've consulted
    Chapelle and he does not really treat this subject other than
    explaining the gluing process.
  2. TeddyDiver
    TeddyDiver Gollywobbler
    Becouse it's much better in many ways.. stronger.. lighter.. long lasting etc
  3. wet feet
    Likes: 303, Points: 83, Legacy Rep: 124
    wet feet Senior Member
    If you look at the publication dates of Chappelle's books they pre-date the availability of reliable waterproof glues.In spite of this,glue was used.The more relevant consideration for masts is that a glue bond is uniformly strong.A line of fasteners is strong at the points where the fasteners are located and will become weaker after numerous cyclic loads are applied.It is also quite difficult to shape the mast if there are fasteners present.If you are building a replica large ship from the mid nineteenth century or earlier different considerations apply.
  4. PAR
    Likes: 496, Points: 93, Legacy Rep: 3967
    With the exception of through fasteners (nut and bolt) a good glue will yield several advantages. A prime consideration is weight aloft. After you count up hundreds of fasteners on a lengthy built up mast, the weight will make you sweat in the first real blow the stick sees. Fastener arrangement, as has been mentioned, can cause a host of issue, like trying to screw a sail track down and having internal fasteners get in the way. Hard points and stress risers are another issue. the fasteners create a localize clamping force that rapidly decreases as you get further from the fastener. Under bending loads this can place surrounding wood under undue stress, causing localized fiber failures. This can be commonly seen as compression around the fastener heads or distortions in the general area, both weakening the mast.
    Applied properly, glues can generate a uniform bond between pieces, stronger then the fibers themselves. This makes a homogeneous column, one that will react uniformly to load, not the dictates of fastener spacing.
    Some masts, box section in particular, will have small brads to hold the stave's in place while the glue cures. These offer little to no structural advantage other then initial alignment.
    Chapelle used and wrote about truly waterproof glues, including resorcinol, plastic resin, which he was fond of and epoxy, which he wasn't completely convinced of yet. He passed in 1972 and was well aware of the "new fangled" goo's.
  5. gonzo
    Likes: 1,494, Points: 123, Legacy Rep: 2031
    Herreshoff was using "plastic" glue for spars in the 1920's already. Chapelle's book is of much later vintage.
  1. Hive_Zach
  2. magentawave
  3. YotaTruck
  4. nivedita
  5. boatenthusiast
  6. laukejas
  7. Steve M
  8. chris1234
  9. El_Guero
  10. AndyBorris
