89 mariner 25 no spark
Discussion in 'Outboards' started by luvnwater, Jun 10, 2012.
  1. luvnwater
    luvnwater Junior Member
    Hi boat lovers. I bought a fishing boat with above motor. Previous owner claimed no spark. He replaced coils still no spark.upon inspecting wires there is a yellow wire with red stripe with a ring connector on end that isnt connected to anything. The previous owner must have not put it back or forgot to connect it back.I bought owners manual but it dosent say what wire it is.Can any of you geniuses help. Thanks in advance. p.s. I took a couple of pics of wires.
  2. thudpucker
    thudpucker Senior Member
    Photos of my 95 Mariner 25 Hp. Maybe this will help. You should post some photos for us.;)
  3. luvnwater
    89 mariner 25
    Wow that was fast . I,ll zoom in and look see. Also I will try to load a few pics ,, Thankx
  4. luvnwater
    that is very similiar. I dont see any yellow wires mine has electric start maybe it is for that
  5. luvnwater
  6. thudpucker
  7. luvnwater
    89 mariner 25
    thankx thud. Ill ck out the site. The wire might not be for cdi ign its just a loose wire that needs to go somewhere. thanks for your help
  8. luvnwater
    89 mariner
    Marineengine.com site I signed up and asked question on there , guy says its 4 starter solenoid but there is all ready a wire on there. I quess I will have to test those wires while I try to crank over motor. I just dont want to fry anything. Will keep u all posted
  9. PAR
    [​IMG]A manual will reveal all. You shouldn't be fooling around with the wires without a diagram. One for your motor will be less the $30.
  10. thudpucker
    Small signal devices.
    The Circuits inside the Coil packs are small Chips (Similar) which run on very small voltages.
    One "ZAP" from the wrong input can destroy a circuit.
    The Static Electricity from moving your arm and touching the Input can destroy the Chips inside.
    Somewhere you'll find a book with a schematic. Maybe the Previous Owner?
  11. luvnwater
    89 mariner 25
    thanks Par I bought a manual but it didnt show me what I needed. Im trying to be careful so I dont burn anything up Thats why I started this thread.I appreciate your time and I will keep trying
  12. thudpucker
    Manual didn't show what you needed?
    No Schemetic of the Terminal connectors on the packs?
    Did the manual cover wire Colors?
  13. PAR
    If you bought the manual I listed, it includes a color coded wiring diagram.
  14. luvnwater
    89 mariner 25
    thud , I,m leaning towards starter circuit there is a brown wire ( small ) allready there the loose 1 is yellow with red stripe. Par the book I got is Seloc I was told it was good.the color code for start circuit shows a yellow from ign swtch to interlock then yellow to solenoid. I will test light both wires monday to see which 1 gives me power when I turn crank. Is the interlock so it doesnt crank in gear ? Thanks guys
  15. thudpucker
    I dont have Electric start. I have a Kill Switch in the Tiller though. Have you found that one?
