1. The Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post boatbuilding tools, drafting tools, molds and tooling, and other professional equipment for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
20'tunnel
Discussion in 'Boat Molds' started by Cobra1, Nov 23, 2008.
  1. Cobra1
    Likes: 0, Points: 6, Legacy Rep: -2
    Cobra1 Junior Member
    For sale 20' tunnel boat molds. This hull has seen tripple digit speeds, and can hold 7 people. It's and open bow picklefork. Can be rigged for jet.I/O or O/B.
  2. MirageBts
    MirageBts Junior Member
    Can you post or send pictures of this boat?
  3. Cobra1
  4. MirageBts
    Thanks for posting some pictures of the pontoon and 20'. I can't really tell anything about the pontoon. Do you have any other pictures? Do you have any pictures of the bottom of the 20'? Is it a true tunnel or modvp? you can email me more info and pictures to MirageBts@aol.com.
    Thanks,
    Brad
  5. Cobra1
    It would be considered a Mod VP, it does have a center pod. The pod is 1" below the out side sponsons, making it a leagal boat to run in the APBA.
    This is showing the plug being lifted out, you should be able to see the center pod and the top of the tunnels with the outside sponsons. It needed a little help with the water hose to float it a bit.
  6. armyranger1994
    armyranger1994 Junior Member
  7. Cobra1
    $7,500.00 and you get the original plug to go with it. This means you own the rights to the tooling. The hull is all glass, so you could put a new deck on it and paint the hull and have a boat to show. Most of the deck is glass other than the front end, that was all done with wood, glass and bondo. You could just build a new glass front and glass it to the deck, quicker than building a new deck.
  8. Cobra1
    You can also make a deck boat out of the hull. Just put bulk heads from side to side and put a floor on it, with hatch's for storage in the center pod and the out side sponsons.
  9. matt1219
    matt1219 New Member
    you still have this mold
    If so please call me at 19515676808 so we can work things out I'm very interested
  10. Cobra1
    will do. mid morning.
  11. Vicious Racing
    Vicious Racing Vicious Custom Boats
    Scott, Giving up on the tunnel project ??
  12. Cobra1
    No, there not going anywhere. This is to keep the devil happy. Devil being, resin hating wife. I can race this open bow in the Comp Jet class and in the Parker 300. Wouldn't that look odd, a seven passanger family cruiser running in a 300 mile enduro.
  13. Vicious Racing
    I keep hopeing to get a email with a pic of a deck plug that has simularites to a 25' Talon !
  14. Cowboy_Mike
    Cowboy_Mike Junior Member
    Are the molds still for sale? email me at mkwdbdr@aol.com. I would like some more info.
  15. Cobra1
    If you have never built a boat, this is not one to cut your teeth on. Start with something small. This boat is 3 times harder to lay up than a V hull, and uses 1 1/2 times the material, for a boat the same length.
