Exactly Mr E, and that same part of the ring has to support the piston as it rides over circa 5% of the cylinder diameter. Id imagine that the rings end up with grooves in them from riding over the narrow bridges between ports... Not long before the seal is no good and the rings need replacement.
Another problem is uneven heat on the piston, as the hot gas escapes out the exhaust port. The inlet side of the piston is always cooler from the fresh fuel mixture entering so you end up with uneven piston expansion. Upon inspecting a siezed 2 stroke, i think everyone ive seen always has the scoring and piston wear on the exhaust side of the piston and cylinder.
