Last fall I bought a pontoon boat with the 95 70hp Evinrude, model # E70TLEOR. This summer I started it up with ears on, and everything seemed fine. But after putting in the water and taking it for a ride, the engine will not start once warmed up. Leave it rest for several hours in cool weather, and it may start. Generally if I let it sit overnight it starts.
Symptoms: Runs fine once started. Can run it for hours with no sign of a problem. However, if it is turned off it will not start when warm. When you try to crank it over, it fires and may cough on what seems like one cylinder and then stops. Tried starting it with the throttle at different positions, and it does the same thing.
Here is what I have done so far to locate the problem
- fresh gas and oil
- cleaned all connectors and grounds, including removing the CDI and coils to clean ground.
- changed fuel filter
-changed plugs
- emptied carb bowls
- sprayed carb cleaner when it ran (when engine was cool and started)
- sprayed fuel in the carb -did the same thing, coughed when starting warm
- checked for spark when it wouldn't start; there was spark on all plugs
- sprayed freeze spray on CDI, coils - Engine still coughed until let sit overnight.
If it happens to start when warm, which it will do once in a while, it runs fine. But turn it off and immediately try to start it, it coughs on what seems to be one cylinder, and stops. Because it tries to fire I generally can't crank it long, a second or two before the starter is disengaged.
One strange thing happened last night. A buddy of mine came over to have a look. While the problem was occurring with the cover off, we noticed when it was coughing, the flywheel seemed to pause a spin backwards before stopping (if that makes any sense).
At this point, I believe it must be ignition since spraying fuel in the carb made no difference. Anyone have any additional tests I should do before I purchase a CDI powerpack?
- fresh gas and oil
-changed plugs
