This is the running surface of a 1986 Wellcraft Scarab 1. The same hull design was used for years across several Wellcraft models. The design uses two full length strakes terminating at the transom in addtion to a partial pad that is slightly rounded at the keel. The hull is unresponsive to trim and rides flat and wet at WOT. This seems to be a systemic issue with this hull configuration. Removing 350 lbs of weight from the engine compartment only aggravates the issue. I've owned a number of high performance boats including both pad and round keel deep V's. but this is the only one that has the inner strake extend to the transom. The pad does exhibit some hook, which is not condusive to bow lift however, others have removed the hook with only a modest bow lift improvement. IMO, the inner strake is lifting the stern at the detriment of forcing the bow down. I don't require as much stern lift having removed so much weight from the engine compartment and I see an opportunity to reduce that amount by another 80 lbs.
I'm thinking of shortening the inner strake to something similar to that of my Nordic Heat, that has no issue with insufficient bow lift. These Wellcraft's become somewhat ill handling over 70 mph with both chine walking and bow steer. I'm speculating that this extended inner strake was designed to keep the stock boat on top with stock power at lower speeds, but is counterproductive when seeking significant speed increases when adding HP.
Opinions or experience?? It's a pretty gutsy move to start grinding off sections of strake on a hypothesis.
