powerabout
Senior Member
- Joined
- Nov 5, 2007
- Messages
- 2,952
- Reaction score
- 68
- Location
- Melbourne/Singapore/Italy
the only part in the engine that can corrode is the exhaust elbow as it is cast iron and has sea water in it.
If it fails it can allow seawater to drain back into the exhaust ports.
It's a consumable, change it if you dont know the age of it.
If you have water in the oil check the seal on the camshaft that is behind the freshwater circulation pump, even though it has a drain hole between the seals.
Start with a cooling system pressure test as you would do on a car
