“End-Plating” the Main and Mizzen
Discussion in 'Hydrodynamics and Aerodynamics' started by kmcfast, May 20, 2011.
  1. kmcfast
    Likes: 1, Points: 0, Legacy Rep: 21
    kmcfast Kmcfast
    Steve Dashew says: In the 1960s and 70s we addressed this issue on our racing catamarans with deck-sweeping mainsails. We found a good seal was worth at least five degrees in tacking angle with no loss in boat speed. If you lifted the seal just six inches, this advantage would be lost.
    http://setsail.com/end-plating-main-and-mizzen/
    Any thoughts for a monohull?
  2. Doug Lord
    Likes: 349, Points: 93, Legacy Rep: 1362
    Doug Lord Flight Ready
  3. messabout
    Likes: 514, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    Decksweepers were in vogue for a time as you mentioned. Decksweeping rigs turned out to be a bit much for crew movement and safety. There were visibility constraints too. Shelves sewn to the foot of sails were also popular for a while. Shelves lost their popularity when some of the class boats began to include the shelf in sail measurement which killed the whole deal. More than one Americas Cup boats tried wide flat booms with sail slides attached to the foot of the sail and tracks on the boom. These were called Park Avenue booms.
  4. philSweet
    Likes: 464, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
    See also here, Tspeer's homepage. Select optimum planform.
    tspeer.com
    - an excerpt -
    Minimum Drag Sail Rigs. For a given span, the minimum drag sail rig has the spanloading which results from a uniform downwash distribution. Figure 4 shows these minimum drag span loadings for gaps between foot and surface that range up to 20% of the span. For zero gap the result is the classical semi-ellipse. Even for very small gaps, however, the optimal loading is quite different. The spanload distribution with gap starts out somewhat egg-shaped, with the point of maximum loading near 40% of the length of the surface. The loading rapidly approaches a full ellipse as the gap is increased.
  5. gonzo
    Likes: 1,728, Points: 123, Legacy Rep: 2031
    The problem is in comparing sail efficiency as measured by a rule and measuring actual sail area. They are usually different.
  6. philSweet
    Of course, you are not only plating the sail, you are also plating the hull- and the hull can provide substantial lift going to windward. I have read windtunnel reports where 14% of the driving force was attributed to the hull when a deck sweeping jib was used. It wasn't clear, however, weather they figured the improved jib performance, or just assigned all added performance (with hull vs no hull) to the hull.
