nero: KD860 catamaran by K-Designs
The boat is an easy to build plywood/glass/epoxy construction. Plans from this designer are quite affordable. This designer has other designs available.
LOA/LWL: 8.60m
Beam: 5.60m
Draft hull/rudder: 0.4/0.7m
Weight empty: 1800 kg
Weight cwl: 3000 kg
Sail area
Main: 27 m2
Jib 10 m2
Reacher: 26 m2
L/B ratio: 1:2
L/B ratio hulls: 1:11
Prismatic coefficient: 0.569
Righting moment max.: 5600 kgm
Optimum speed: 21.5 kn
Outboard engines 2x 6 HP
Construction time about 1200 hours
http://www.ikarus342000.com
- Category:
- Sailboats - Multihull
- nero
- Feb 10, 2006
