DIVA Concept MegaYacht
Carlos Cifani
Carlos Cifani: DIVA Concept MegaYacht
270LOA Super Yacht DIVA
Posted by: Carlos Cifani - website: http://
Tags:
Carlos Cifani, Jan 28, 2003
    • Uli
      Nice design
      But don't you think that you will get trouble in the wave with that thin front. I mean you got a lot of volume in the back but nearly nothing in the front. I think that the boat will stamper pretty much on a on wind sail cours.
    • Carlos Cifani
      Uli, thanks for comments.
      Actually we are developing some hull extreme lines with good results in test bench, under huge stress for consideration in future edge projects.
      Carlos
    • Rating:
      5/5,
      mackid068
      um, how hydrodynamic is that boat? Also, it doesn't look too stable...maybe add outriggers. Still, if the technology, math and engineering play out, that boat looks REALLY REALLY cool.
    • Rating:
      1/5,
      Enzo Mlinari
      It's obvious you have never sailed a boat. This one is terribly unstable: to narrow in the middle-section. Even with 50%ballast it will kant.
    • Rating:
      1/5,
      BTG YACHT DSGN
      It was supposed to be conceptual, but you cannot forget, that design accually means, that "form follows function", so the form should not be separate from practica/performance consideration. You should notice that in your future projects.
      anyway keep going with the design.:)
      good luck :D
  • Category:
    Carlos Cifani
