What is this???
Discussion in 'Metal Boat Building' started by fewfish, Nov 28, 2011.
  1. fewfish
    fewfish Junior Member
    Hi
    I came across this picture on the internet.
    What is the exact purpose of this black floor? What is this floor called?
    Regards!
  2. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    Its a full scale drawing of the plumbing layout to guide the installers, what fits where.
  3. fewfish
    Hm.. That seems useful. Where can one order something like this?
  4. tunnels
    tunnels Previous Member
    aaaah you could make your own !! :idea::)you could use your imagination ?? :confused::confused:
  5. gonzo
    Likes: 1,734, Points: 123, Legacy Rep: 2031
    Once you have the blueprints, you need a printer of sufficient width. Another option is to use a smaller printer in banner mode and then join the strips.
  6. anhdtht
    Likes: 0, Points: 0, Legacy Rep: -24
    anhdtht Junior Member
    I think it is drawing of a pump on ship
  7. PAR
    That looks to be a laser cut piece(s) of likely Masonite (or other cheap material), with the hardware mapped out for installation. As the elements are installed, the cutout pieces are removed and this can eliminate errors in reading the plans or confusion with less then skilled workers. There's no guess work, or worse, a "judgement call" made by an installer, that potentially compromises other areas or aspects of the build.
  8. troy2000
    troy2000 Senior Member
    Having been a tract superintendent for a while (among other things), I could give you a few horror stories about 'judgment calls,' especially those involving plumbers.
  9. PAR
    That's precisely why the laser cut diagram is in place Troy. Anyone in the industry, land based or marine can tell you horror stories of pipe fitters cutting huge holes in structural elements to get their stuff installed, plumbers cutting HAVC duct work to run pipes, electricians using gas pipes as a ground, the usual stuff. The diagram makes the 2D drawing a real 3D thing, in place, on the job site. You don't have to have workers that can read plans or even ones that can make reasonable decisions, which means less cost in the labor and a more precisely followed set of plans.
  10. waikikin
    waikikin Senior Member
    Dunno if its still done but years back there was specialist draftsmen/modelmakers that would create scaled segments of chemical plants etc to "prove" the runs & create a tangible model for the engineers & fitters to follow.
  11. PAR
    Yep, it's still done, but now we can "walk through" the model on the screen. You can simulate moving a replacement piece of equipment through the structure, to see if it'll clear in route, etc.
  12. fewfish
    In any case this seems like a good idea. I had many conflicts on construction site because printed plans were lost, misinterpreted or ignored.
    I was wondering weather there are companies that make floors like this... I could draw something like this, but I do not want to, because it is going to be time consuming and at the end expensive. Company that makes a living out of this surely can offer this service at a competitive price.
  13. PAR
    Fewfish, what's more expensive, skilled labor costs to install things properly and to plan or a cardboard cutout, with all the equipment visually identified and placed about where it needs to be, so that low skilled labor can install it to the plan?
  14. cor
    Likes: 12, Points: 0, Legacy Rep: 85
    cor Senior Member
    I saw some tract housing being put in where all the houses were the same design, but some of them were a mirror image. The developer was too cheap to make mirror image copies of the plans, instead the plumbers had to hold the regular plans up to a light and look at the back side if they wanted to see what the house looked like! Lots of pipes installed under slabs in the wrong locations on that job.
    C.O.
  15. loveyachts
    Likes: 1, Points: 0, Legacy Rep: 40
    loveyachts New Member
    I think you are right! :cool:
