The Riddle
Discussion in 'All Things Boats & Boating' started by PAUL XAVIER, Jan 8, 2016.
  1. Angélique
    Likes: 337, Points: 83, Legacy Rep: 1632
    The result is basically similar, but the outcome of the experiment will be much more significant.
  2. Tiny Turnip
    Likes: 278, Points: 63, Legacy Rep: 743
    Tiny Turnip Senior Member
    indeed! :D
  3. Tiny Turnip
    and it does rather beg the question of the pre-existing condition!
  4. ImaginaryNumber
    Examining the extreme limits can sometimes clarify situations which appear ambiguous around normal conditions. Computer Scientists are taught to test their programs at zero and +/- the largest number their computer can generate, for instance.
    So pretending the stone has a large mass but negligible volume may clarify what is happening in the OPs riddle. You could also imagine that the stone has little mass but a large volume (a helium balloon).
  5. JSL
    JSL Senior Member
    No stone is left unturned!
  6. philSweet
    Likes: 463, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
    The mechanical approach - Use a chain of simple actions to get from start to end. The effects of each action are understood to be analytic. So begin with a boat, rock, string, and lake. The system is quiescent. Gently use string to lift rock in air and stop. Evaluate lake level. Gently immerse rock in lake, holding string which is still has some tension on it. Evaluate lake level. Release string. Evaluate lake level.
    The properties approach. Identify the mass and volume of each component. Since the rock sinks, we know the derived quantity density of the rock is greater than the density of the lake. Predict the result based solely on properties of the system's components without any consideration of the mechanisms involved.
  7. Mr Efficiency
    The OP hasn't returned to complain, so it must have answered the homework question.
  8. hoytedow
    Did you hear about the flock of seabirds which came across some jettisoned drugs?
    No tern was left un-stoned.
