Nordhavn
Discussion in 'Powerboats' started by Guest62110524, Aug 6, 2009.
  1. apex1
    apex1 Guest
    They do´nt need! They afford the best marketing (for the most ugliest boats imho).
    And they sell it where it belongs: the US market.....................
    Each and every of the NA´s around here, and each and every of the professional boatbuilders could tell you, that a custom made Passagemaker of the same spec.s would cost about 50% of those "yoghurt cups" and they would be built to class standards! look:
    http://www.boatdesign.net/forums/me...o-anywhere-trawler-build-side-side-28678.html
    Regards
    Richard
  2. Guest62110524
    Guest62110524 Previous Member
    maybe Most think they are hansome
    if I had that sort of money I would be asking for cert this cert that
    i guess Nordhaven have their own quality control over there
    but you get people buying yachts because the curtains are pretty,
    I myself like them, especially the range and cost of motoring
    underwater shapes are good They look safe and probably are safe
    i Know how hard it is to break into the USA market
    boatbuilding is not all just boatbuilding!
  3. taniwha
    Likes: 10, Points: 18, Legacy Rep: 150
    taniwha Senior Member
  4. ABoatGuy
    ABoatGuy Member
    See attached from IMCI.org - listing of Nordhavn's CE certified (all Cat A) by IMCI. These are type certificates. Larger boats are certified B+G individually and are certified by HPi in the UK.
    As for classification societies, most will only class a boat over 24m, which eliminates all Nordhavn's but the 86. See attached from ABS (eagle.org). This is the listing for one of the 86's. I am told two others are in progress with ABS.
    So, just to clear things up, yes they can be CE Certified CAT A and yes, they have been classed when possible.
      File size:
      39.1 KB
      File size:
      73.9 KB
  5. Paul Kotzebue
    Paul Kotzebue Previous Member
    Thanks for the data. I appreciate the clarification.
