extending transducer's cable
Discussion in 'OnBoard Electronics & Controls' started by raf pali, Dec 18, 2015.
  1. raf pali
    Likes: 1, Points: 8, Legacy Rep: 12
    raf pali Junior Member
    Hi all. Does anyone know if extending a transducer's cable is possible without faltering the depth-sounder's reading?
    Thanks in advance.
    Cheers
  2. PAR
    Extension cables are available for most models.
  3. gonzo
    Likes: 1,728, Points: 123, Legacy Rep: 2031
    Sometimes you will need to re-zero it, but that only takes a couple of minutes.
  4. raf pali
    Thank you very much for your valuable suggestions. Have done the job today and works fine.
    Cheers
  5. JSL
    JSL Senior Member
    Check with the mfr.
