current wisdom on electric
Discussion in 'Hybrid' started by Anatol, Dec 22, 2015.
  1. Anatol
    Likes: 0, Points: 16, Legacy Rep: 10
    Anatol Senior Member
    regen again
    Right, I'd thought about that- or drop it over the transom like an outboard. Id does seem like uneccessary duplication tho. But it would allow for a feathering prop.
    Can someone outline to me why regen efficiency is so poor. Is it simply that the motor is not optimised as a generator?
    It seems like, for our purposes, regen is a key capability - I'm keen to understand more.
  2. Anatol
    good point
  3. powerabout
    powerabout Senior Member
    I think a purpose built regen system you drop over the back when stopped might be the go?
  4. gonzo
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    There are some in the market that look like a small outboard. The propeller is optimized for the job. I suppose a trolling motor could be modified.
  5. FAST FRED
    FAST FRED Senior Member
    To push a boat well a large diameter slow turning prop is required.
    To pull HP from the water the dame big diameter and slow speed is required.
    If its efficient it is a SPEED BRAKE.!
    Fine on a sail boat just below hull speed , where more power would just make a bigger bow wave , otherwise much un fun.
