current wisdom on electric
Discussion in 'Hybrid' started by Anatol, Dec 22, 2015.
  1. Ebeneezer
    Ebeneezer Junior Member
    My friend uses a portable honda genset converted to propane to complete his hybrid setup.
  2. Anatol
    Likes: 0, Points: 16, Legacy Rep: 10
    Anatol Senior Member
    Thunderstruck!
    Thanks all for replies and Thunderstruck link. Don't know how I didn't find them before.
    Great stuff. Love the regen. Love the reverse on the fly. Prices are great. The 10 or 12.5 kw option looks right for my boat.
    Some kind of custom face plate/linkage and motor mount to mate with the A4 V drive is needed. That seems a fun design/machining project :)
    Kit seems to supply all except linkage/mounts and batteries. Any advice on new/economical options... Weight is not a big deal for me, Halcyon is 8 tons, and without the big block of iron, I can install 8, 10, or 12 conventional lead acid cells.
    Living in Socal, there lots of sun, so next step is a great in harbor solar panel bank. And the water stays cool, so cooling is not such a big deal - drawing air along the bilge will provide refrigerated cooling air :)
  3. Anatol
  4. Anatol
    Thanks for links to your project and to Golden motor - very interesting. The liquid cooling is an interesting feature. With Heat Exchanger this may work well. Maybe I can tie in a hot water tank for showers :)
    Hope new year in Finland isn't too grim :)
  5. Ebeneezer
    Personally I would use lead acid Trojan golf cart batteries and use a propane converted honda genset on deck. You can convert to propane for about 100 bucks. This keeps the system cheap and cheerful without paying for anything exotic.
  6. Anatol
    I'm wondering - hoping - that in socal sun and with regen, a generator *may* be unnecessary... that would be ideal. My boat hits hull speed easily, and drags the prop around at 5.5 k. So there is energy to be reaped with no extra hardware. It is wind generator by other means :)
  7. Ebeneezer
    All depends on how far you plan on motoring but a back up portable genset would give you peace of mind for minimal cost.
  8. Anatol
    regen
    The golden BLDC motors look interesting. The thunderstruck motors are AC and they make a lot of regen, whereas Golden do not mention it. Is regen an AC thing, what are the pros and cons of regen with DC and AC?
  9. FAST FRED
    FAST FRED Senior Member
    " My boat hits hull speed easily, and drags the prop around at 5.5 k. So there is energy to be reaped with no extra hardware. It is wind generator by other means "
    If you load down the prop it will work as a speed brake .
    Drag a pail of the same diameter as the prop (15-20 inches?) to see how you like the effect.
    There are special slow speed wound alts that will produce DC at the low shaft speed rotating under sail 100-200RPM?
  10. philSweet
    Likes: 461, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
    Anatol, the regen is a complete nonstarter. Not even 2% efficiency is possible in your application. You want to reduce drag, not increase it. You want a small, folding sailor prop. Reducing drag is the best money you can spend.
  11. Ebeneezer
    Very true forget about the regen possibilities in a sailboat.
  12. cmckesson
    Likes: 7, Points: 18, Legacy Rep: 55
    cmckesson Naval Architect
    I often anchor in areas with strong tidal currents, and have wondered about the feasibility of regen while anchored...
    But I do concur with Phil that the efficiency of a prop in the regen half of the quadrant is quite poor. It might be more efficient to tow a purpose-designed water generator.
    On the other hand, if you controller has regen built in, go ahead and use it! My rig is a series wound DC motor, and regen would be quite an expensive controller upgrade.
  13. gonzo
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    Before using your propeller for regeneration, make sure freewheeling won't damage the transmission. Some will overheat or wear out the clutches/bands.
  14. schakel
    Likes: 16, Points: 18, Legacy Rep: 48
    schakel environmental project Msc
  15. powerabout
    powerabout Senior Member
    It only makes sense if you have renewable power
